3 members (Pre '68 Dave, 52Carl, Bill Marlow), 50 guests, and 2 robots.
Topics128,090
Posts1,056,028
Members48,432
Are the spring perch widths different between a 1946 and a 1952 half ton? Just trying to find out options on rear ends.
Joe has provided the center to center spacing of the perches, which is probably what you needed to know, but just in case you need the width of the perches, they are 1 3/4" in both cases.
You can pick up 1 3/4 spring perches at your local trailer store and just weld them to what ever rear end you choose.That's what i did.
layback
