0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | i put a 4" drop axle on my 51 3100. Does any know of a doner vehicle that i can use the steering arms off of so i can get the tie rod back under my leafs?
John | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | I have a three inch drop axle with mono leafs, What I did to get my tie rod under the leafs is I used the new modern style tie rod ends that most vendors sell and flipped them to the bottom of the steering arms also to keep my drag link parallel I flip that also. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | I have a 4" drop axle on my 54 also. The front end alignment shop heated and bent the steering arms down abt. 1/2" so everything would clear. This was an "old skool" suspension shop thats been around since the '50's. Theres no prob heating and bending those pieces if its done right. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Marty... would that be More-Drop in oakland? | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | hey Chato what all did you have to do to put the new style tie rod ends on.
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Bigbadswingdaddy...Correct. I bought my 4' drop axle from Mor-Drop. The guy's been there forever! I bought my 3' drop axle from www.droppedaxles.com | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | i might have a set of tie rod ends i did the same modifaction | | |
