2 members (2-Ton, JW51),
67
Mod | | | Forums66 Topics128,055 Posts1,055,783 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 8 New Guy | | New Guy Joined: Jan 2011 Posts: 8 | i can get the body work to where i like it but i am confused on what would be the proper primer to use. the truck will be in primer for some time so tell this dumb old guy what would be best. thank you. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What will you be doing to the metal before priming? If you are down to bare, non-rusty metal, an epoxy primer will seal it and can be roughed-up later for sealer/surfacer and/or filler.
| | | | | Joined: Jan 2011 Posts: 8 New Guy | | New Guy Joined: Jan 2011 Posts: 8 | yes, most of it will be bare metal. like the bed side will be taken down and then i need to primer. epoxy sounds best as it will be some time before i get to final prep and paint. all indoor storage. | | |
