6 members (Lightholder's Dad, klhansen, GRNHydra, Mike Roache, Maybellene, 6inarow), 87 guests, and 2 robots.
Topics128,035
Posts1,055,552
Members48,425
#722543 02/20/2011 12:20 AM
I have a 37 1/2 ton tuck and I recently found a pair of amber fog lights in an old shed on the farm the truck came from. Is it possible that these would be for my truck or were fog lights not common in 37 on trucks?
http://i543.photobucket.com/albums/gg447/Seykoras/2-19-11010.jpg
http://i543.photobucket.com/albums/gg447/Seykoras/2-19-11011.jpg
37FamilyBowTie #722551 02/20/2011 12:43 AM
I'd say fog lights on anything in 37 would have been uncommon, certainly extra cost options if even available from GM - most likely those are aftermarket .... but they do look like period pieces. with the mounts meant for the bumper irons
37FamilyBowTie #722552 02/20/2011 12:47 AM
I've seen a lot of mid 30's to early 40's trucks and cars with fog lights like those. They were "dealer options" back in the day. I think they look cool - great find!! Bolt them suckers up and burn holes thru the fog!!
tcox #722564 02/20/2011 1:26 AM
Im with "tcox". Bolt em on, see how you like them.
If not, take them off. No harm done.
Ex Hall Monitor
Ex Hall Monitor
Common or not those are period correct and would look good on your '37. Check the link s in my sig to see how they'll look. Are they sealed beam?
Tiny #722813 02/20/2011 9:02 PM
They are not sealed beam but I tested them today and they still work. The funny thing is that they were in a shed that collapsed due to snow load on the roof and I would have never found them unless the thing caved in!! I think its meant to be and they will be going on the truck!! I am surprised they weren't smashed when the roof fell in!!
Thanks for the help!!
Charlie
37FamilyBowTie #722853 02/20/2011 11:29 PM
Ex Hall Monitor
Ex Hall Monitor
Just for grins what bulb do they use? I'm guessing an 1133.
Tiny #722862 02/21/2011 12:04 AM
Year : 29-36
Rating : 32
Use : Fog Light
Bulb No. : 1323
Filaments : Single
Volt : 6?
Year : 37-42
Rating : 32
Use : Fog & Passing Lamps
Bulb No. : 1007
Filaments : Single
Volt : 6
tclederman #722871 02/21/2011 12:46 AM
You are right Tiny.
They have a GE 1133 bulb in them.
Charlie
Ex Hall Monitor
Ex Hall Monitor
The candle power is about the same for the 1323 and the 1133 but the 1323 has the prefocus base. Should be plenty bright if the reflector is good.
