| | | Forums66 Topics128,100 Posts1,056,513 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 47 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 47 | hi, can someone tell me where on the truck i should put the floor jack so i can take off the wheels to grease the wheel bearings? would anywhere on the main frame be ok? it's a 1950 chevy 1/2 ton. thanks.
Che 1950 Chevy 3100
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy che, you can place the jack under the front axle, either one side at a time or jack it up in the center and place it on axle stands, hope that helps. | | | | | Joined: Sep 2010 Posts: 47 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 47 | oh really? i was afraid i would bend it. thanks for the information.
Che 1950 Chevy 3100
