3 members (55shaker, Stovebolt48, Otto Skorzeny), 63 guests, and 1 robot.
Topics128,079
Posts1,055,941
Members48,430
#721152 02/15/2011 3:33 AM
what year 700r4 and rearend gear for a daily driver
You'll want an '85 or later transmission, the early ones have weak pumps. For the rearend gear, that will partialy depend on overall usage plans and also tire size. Having said that, I have an S10 with a 700R4, 235/75/15 tires and a 4.10 rear gear, it works very well. Without knowing what year truck, engine size, tire size, and what rearend is in it (stock, later truck, Camaro, etc) It's somewhat difficult to give an exact gear ratio, as it can vary on availablity for a given differential. I can say that 3.73-4.11 would be a good range, though. Might even be able to go with a 3.42 if you have enough engine to pull it.
Bill Burmeister
I have a 700R4 in mine. Running a 3.73 gear with a 350HP Chevy 350. It's a Bowtie Stage 2. Get out your checkbook!
Joe V.
JoeV #722143 02/18/2011 4:24 PM
I have one using a 350 & 3.42 gears, love it, will get 17 mpg+, not bad IMO for a truck w/aerodynamics of a brick & pretty heavy too...
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
