1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
These puppies...
http://www.classicparts.com/1957-59-Spring-Shackle-Kit-FrontRear/productinfo/74-022/
LMC does not carry the above style with the retaining nuts on the ends of the pins and Classic has them on back order....
Are there any sources for the above shackle kits excluding LMC and Classic.
thanks,
Chuck
try the filling station, chev's of the 40's, jim carter....
GMC: Get More Cash...
1958 GMC
My Webshots photos
have you checked NAPA? local or online, they just might have'em in the system
Might check with the local spring shop, they might have them as well.
Bill Burmeister
Geezer
Geezer
NAPA part number is: NCP 2741766 $43.49
for the shackle kit..
TC
1966 C20 LWB, 327 4 Bbl., 4 Speed
You may be having the same deal as the '54 ones. Everyone lists them but they are on "back order" because they are no longer being manufactured.
I was trying to search for that NAPA P/N as I remembered seeing it in a past thread that I had read. I must have search for an hour.....at any rate Jim Carter had them and bought two from them. Fist order I have given these folks as well...anxious to see their catalog come with the order as well..Thanks for your help fellas
