7 members (klhansen, 87GN, tclederman, Stovebolt48, Peggy M, baldeagle, 1 invisible), 117 guests, and 1 robot.
Topics128,048
Posts1,055,666
#721346 02/16/2011 12:30 AM
I usually don't drive my 54 pick-up in the winter but just notice yesterday that the heater is blowing cold air. The rest of the cooling system is working fine. Where should I start looking for the problem?
Look under the hood on the heater hoses and see if there is a valve, if so it may be turned off.
Tommy
59 apache 1/2t
261 short stepside
Tommy #721351 02/16/2011 12:39 AM
Thanks, No valve, it worked fine last year.
You may need to back-flush the heater core.
Also make sure the radiator is full.
My Blog
Riding in the Passing Lane
First is the therm. working for the engine to get to operating temp? With the engine warmed up & the rad full grab the heater hoses with your hand. Both hoses should be hot enough that you can only hold on for a few seconds. If one hose is hotter then the other then the restriction is were that hose came from. If both are cold your engine is not warming up. You can blast a little air in the heater core with a rag around the blow gun to flush it out.
1972 Chevy c10 Cheyenne Super
Quote
Wouldn't the hose going to the heater be hotter than the one coming from it in normal operation?
No. If circulation is good they will both be about the same.
