1 members (Otto Skorzeny),
90
Mod | | | Forums66 Topics128,090 Posts1,056,380 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 16 New Guy | | New Guy Joined: Dec 2009 Posts: 16 | on the rear bed mount their is a 4" block that sits under the rear plank that has a rubber pad under it.My problem is the block seems to short about 1/2" does the rear bumper bracket sit on top of the frame to take up space? Joe should know this thanks pierce
peter foster
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Put this address in your browser and ther are several shots of the rear bumper on my truck. The bed on mine is sitting on a piece of steel channel as a crossmember and has a 2 - 1/2" block under it between it and the frame. There is one just after the frame goes over the rear axle and right at the end of the frame on the rear. At the front, there is a steel crossmember and a round piece of composite material on a 1/4" thick piece of rubber. http://www.joefuchs.net/gallery/gallery.php?eventid=5
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
