| | | Forums66 Topics128,109 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | try the filling station, chev's of the 40's, jim carter....
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | have you checked NAPA? local or online, they just might have'em in the system
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Might check with the local spring shop, they might have them as well.
Bill Burmeister | | | | | Joined: Oct 2010 Posts: 33 Geezer | | Geezer Joined: Oct 2010 Posts: 33 | NAPA part number is: NCP 2741766 $43.49 for the shackle kit..
TC
1966 C20 LWB, 327 4 Bbl., 4 Speed
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You may be having the same deal as the '54 ones. Everyone lists them but they are on "back order" because they are no longer being manufactured. | | | | | Joined: May 2010 Posts: 30 New Guy | | New Guy Joined: May 2010 Posts: 30 | I was trying to search for that NAPA P/N as I remembered seeing it in a past thread that I had read. I must have search for an hour.....at any rate Jim Carter had them and bought two from them. Fist order I have given these folks as well...anxious to see their catalog come with the order as well..Thanks for your help fellas | | |
