4 members (ronsway, Wally / Montana, 2 invisible), 148 guests, and 6 robots.
Topics128,078
Posts1,056,052
Members48,433
#720844 02/14/2011 2:27 AM
Just went to adjust the valves on my 59 with a 235 and much to my dismay there is no ballbearing on the flywheel.after hours of looking I noticed a small triangle stamped into the flywheel. Is this the timing mark?
phnman23 #720849 02/14/2011 2:43 AM
Get some acetone on a rag and do more cleaning on the flywheel. You should be able to find the bb once you get it cleaned up more.
don stocker #720889 02/14/2011 4:42 AM
There must be a ball, it is close to the triangle. The triangle is for checking cam timing.
My Blog
don stocker #720947 02/14/2011 2:16 PM
ive found the simplest to do this is to remove flywheel dust cover to expose the bottom of the flywheel. clean/rotate, clean/rotate until you go all the way around. you'll see the mark. what i do after that is to paint the U/C white and polish the ball up nice and shiney. might as well, that way some time down the road when you revisit this (and you will) it will be still easy to see and find. laalaa
51 ashton #720962 02/14/2011 3:30 PM
ok i'll look some more thanks guys , will report back
phnman23 #720976 02/14/2011 4:05 PM
Is there a mark and ball bearing on all years ? I have a 54 3100.
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
phnman23 #720979 02/14/2011 4:08 PM
You don't need to see the timing ball to adjust valves, but it's good to have it well-visible for setting ignition timing. By watching the movement of the rocker arms, you can determine which cylinders' valves are ready to adjust. I use a method called "companion cylinder" valve adjustment, where I watch the rocker arm motion on one cylinder, and adjust the valve clearance on another one that's at the top of the stroke at the same time. I'll see if I can find one of the threads where I've detailed the procedure, and post a link to it.
Edit: Check out this thread:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=661274
I just noticed that thread covered adjusting hydraulic lifters. If you've got a solid-lifter engine, do the "rocking" thing the same way, but use a feeler gauge to set valve lash instead of the "zero clearance plus 3/4 turn" procedure. If you're doing a rough adjustment on a cold engine, set the valve clearance about .002" wider than specification, run it to normal operating temperature, and re-check the clearance after it's warmed up.
Jimmi_V #720997 02/14/2011 4:55 PM
I am not sure when it started, but I am working on a 1936 right now and it has one, so at least 1936-62 has a timing ball.
My Blog
ah ha found it don't know how i missed it , eyes aren't what the used to be. I had to take the flywheel cover off and there it was in between two hash marks and right after a triangle. Adjusted the valves sounds sooo much better also found in the process the pickup tube to oil the roker arm assembly was broken and no oil getting to the valve train, little silver soldering and presto good as new
thanks guys
phnman23 #721040 02/14/2011 8:51 PM
now to tackle my temp sending unit problem, guage will go all the way to hot after a few minutes , but I know the water in the engine is not that hot. I have no idea what temp thermostat is in it maybe too hot , I'll pull it and see if tht helps
phnman23 #721054 02/14/2011 9:47 PM
A 59 will have an electric gauge.
You might try changing the sender.
My Blog
