0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | Just went to adjust the valves on my 59 with a 235 and much to my dismay there is no ballbearing on the flywheel.after hours of looking I noticed a small triangle stamped into the flywheel. Is this the timing mark? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Get some acetone on a rag and do more cleaning on the flywheel. You should be able to find the bb once you get it cleaned up more.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There must be a ball, it is close to the triangle. The triangle is for checking cam timing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | Get some acetone on a rag and do more cleaning on the flywheel. ive found the simplest to do this is to remove flywheel dust cover to expose the bottom of the flywheel. clean/rotate, clean/rotate until you go all the way around. you'll see the mark. what i do after that is to paint the U/C white and polish the ball up nice and shiney. might as well, that way some time down the road when you revisit this (and you will) it will be still easy to see and find.  | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | ok i'll look some more thanks guys , will report back | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Is there a mark and ball bearing on all years ? I have a 54 3100. Thanks | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | You don't need to see the timing ball to adjust valves, but it's good to have it well-visible for setting ignition timing. By watching the movement of the rocker arms, you can determine which cylinders' valves are ready to adjust. I use a method called "companion cylinder" valve adjustment, where I watch the rocker arm motion on one cylinder, and adjust the valve clearance on another one that's at the top of the stroke at the same time. I'll see if I can find one of the threads where I've detailed the procedure, and post a link to it. Jerry Edit: Check out this thread: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=661274I just noticed that thread covered adjusting hydraulic lifters. If you've got a solid-lifter engine, do the "rocking" thing the same way, but use a feeler gauge to set valve lash instead of the "zero clearance plus 3/4 turn" procedure. If you're doing a rough adjustment on a cold engine, set the valve clearance about .002" wider than specification, run it to normal operating temperature, and re-check the clearance after it's warmed up. Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Is there a mark and ball bearing on all years ? I have a 54 3100. Thanks I am not sure when it started, but I am working on a 1936 right now and it has one, so at least 1936-62 has a timing ball.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | ah ha found it don't know how i missed it , eyes aren't what the used to be. I had to take the flywheel cover off and there it was in between two hash marks and right after a triangle. Adjusted the valves sounds sooo much better also found in the process the pickup tube to oil the roker arm assembly was broken and no oil getting to the valve train, little silver soldering and presto good as new thanks guys
| | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | now to tackle my temp sending unit problem, guage will go all the way to hot after a few minutes , but I know the water in the engine is not that hot. I have no idea what temp thermostat is in it maybe too hot , I'll pull it and see if tht helps | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 59 will have an electric gauge. You might try changing the sender.
