2 members (Otto Skorzeny, 1 invisible), 136 guests, and 1 robot.
Topics128,109
Posts1,056,266
Members48,439
#72025 01/22/2007 2:57 AM
I am putting a 4 speed tranny in my 51 half ton. The 3 speed died. I got the correct u-joint from Tom Myers and cannot get the old speedo drive gear off the old u-joint.
I tried tapping with a hammer and brass punch and warmed it with a torch and it still did not move.
Any ideas?
Richard
#72026 01/22/2007 3:07 AM
Maybe try putting the whole thing in the freezer 'till it's frozen then heat up just the gear portion with a propane torch while pry and/or wedge it off.
#72027 01/22/2007 3:13 AM
Thanks, I will try that tomorrow. I have packed old tractor sleeves with ice before to get them to turn loose and it worked when nothing else would.
#72028 01/23/2007 2:46 AM
I put a new U joint in my truck recently and had to wap the speedo gear. Its a ***** to get off. I used some heat, a bearing splitter and a hydraulic press. Got it off the old one and on the new one with no problem.
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
#72029 01/23/2007 2:55 AM
ndnchf,
When you put the new gear on the shaft, did you just drive it as far as it would go? Or, is there a measurement for the correct location?
Tim
#72030 01/23/2007 3:56 PM
I just replaced every moving part in the driveline of my '50, 3604. I replaced my old worn u-joint with a NOS 3689288 u-joint assembly and pressed off the gear the same as 'ndnchf'. Just be careful which bearing splitter you use because there is only a very small land on the back side of the gear and you don't want to support it on the teeth. I used a splitter out of a set from HF. The press I used is a small channel iron bench press my Pop made with an inverted 1-1/2 ton bottle jack. With the pressure pumped up full I heated the gear with a propane torch, not enough to even smoke the oil and it popped right off.
TC, the gear has a heavy chamfer that faces out or rearward toward the spline. The surface that faces the front or u-joint trunnion is flat and should be press up tight against the yoke.
Now mind you, this was a 3/4 ton and I don't know if the 1/2 ton is different.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#72031 01/23/2007 4:35 PM
Denny,
Thanks for the information. The 1/2 ton truck and the larger truck 4-speeds should be the same for the speedo gear.
Tim
#72032 01/23/2007 11:21 PM
There is a shoulder on the U joint that the gear presses up against.
#72033 01/24/2007 3:20 AM
Denny & ndnchf,
Thanks for the information. I am now not so scared to go in there to install the gear.
Tim
#72034 01/24/2007 3:40 PM
Tim, just one more word bout the gear, this pic shows the chamfered and flat side quite clearly.
http://rides.webshots.com/photo/2047967170098611668iaEHVD
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
