| | | Forums66 Topics128,056 Posts1,055,798 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#72016 01/22/2007 12:19 AM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Current dilimma. I have installed a 1954 235 in my 1946 half ton in a ground up restioation and am wondering what options exist for transmission selection. I know of the T-5 swap but what other options are there for a limited budget, lack of knowledge and enclosed drive shaft? | | |
#72017 01/22/2007 2:42 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The only original options, requiring no driveshaft alterations, would be a three speed or a crash box four speed. Patrick's, in Casa Grande, AZ, has an adapter for a torque tube to Saginaw four speeds and Larrowe in Oregon has gearsets to convert the Saginaw to an overdrive forth gear, but that is very pricy. | | |
#72018 01/22/2007 3:33 AM | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | I would think an older manual 4 or 3 speed would be your best options for the money. There are lots of trucks sitting around in Maricopa and North Phoenix with original transmissions that are probably pretty cheap.
Good luck! | | |
#72019 01/22/2007 7:12 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Not many options for an enclosed driveshaft! Not many for a low budget either! Some transmissions make more sense than others when it comes to gear selection, shifter location, speedometer hookup and general adaptability to your chasis. Figure out what it is you want to do with your truck, and then figure out a transmission that is in touch with your budget.
A t-5 is a pretty good low budget transmission, but it will also require rear axle work... which will increas the total install cost. You will also need an adapter plate between your bellhousing and transmission. This could also cost anywhere from $200- $800. | | |
