3 members (Otto Skorzeny, MNSmith, Gray_Ghost), 63 guests, and 1 robot.
Topics128,057
Posts1,055,812
#720050 02/11/2011 3:11 AM
I have had this problem for a while. I can't get my fuel gauge to read. It reads just over 1/4 all the time. I put in a new gauge, a new sending unit and new wiring. I grounded the sending unit at the tank. I don't know where to go from here?
terrygem #720064 02/11/2011 3:43 AM
Sounds like your sending unit is the wrong ohm range for your gauge.
Cletis #720070 02/11/2011 3:53 AM
I just ordered it. could it be for a 12 volt?
terrygem #720080 02/11/2011 4:43 AM
My fuel gauge read FULL all the time so I put in a new sending unit and now it reads 1/4. I don't know what to check next.
terrygem #720081 02/11/2011 4:44 AM
You should tell us what you are working on, whether the gauges are stock type or aftermarket and what tank and sending unit you are using. Oh, yeah, what voltage you are working with.
Cletis #720082 02/11/2011 4:46 AM
I have a 1950 chevy truck..6 volt. The gauges and sending units are all new from Carters. These are all stock type.
terrygem #720110 02/11/2011 6:38 AM
Removing the wire from the sending unit and grounding it should peg the gauge on empty. If it doesn't, check the wire for continuity. If the wire is good the gauge may be bad.
If the gauge proves good, remove the sender and check the resistance through it's travel. It should vary from 0 to 30 ohms.
tclederman #720186 02/11/2011 6:33 PM
Looks like I had it backward. I'll edit it.
Cletis #720220 02/11/2011 10:16 PM
May sound crazy. But I put a new sending unit on mine and it did not work ether. I took it out and what happined was the float had a hole and filled up as fast as I installed it. So I just put on a new one. Have you tryed hooking it up out of the tank and moving it up and down.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
GrandpasTruck #720300 02/12/2011 4:46 AM
I have two gauges and two sending units. Can't seem to get anything working. Will have to start all over again .Thanks for your help.
terrygem #720418 02/12/2011 5:40 PM
Check to be sure you're getting 6V from the ignition switch. If out of the truck hook the gauge (ign side) to +6V bat terminal with sending unit attached to other gauge terminal. Ground sending unit body to - bat terminal. Moving sender arm up/down should move gauge. That will determine if the units are working and give you a starting point.
Ed
