4 members (baldeagle, Joe H, Bill Hanlon, Jon G), 118 guests, and 4 robots.
Topics128,014
Posts1,055,333
Members48,419
#718806 02/06/2011 11:39 PM
My Saginaw three speed is leaking gear oil around the bottom counter shaft where it comes through the front of the case. Is there an o ring or a seal on the inside?
Big T #718870 02/07/2011 3:11 AM
If memory serves, the counter shaft just fits tightly in the hole, during assembly you would put a small amount of gasket sealer in the hole just before the shaft is slid in. You do not want to use a silicon sealer there.
Thanks Truckrolet, That is the one thing I did not take apart when I put in the new gaskets.
