| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | My Saginaw three speed is leaking gear oil around the bottom counter shaft where it comes through the front of the case. Is there an o ring or a seal on the inside? | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | If memory serves, the counter shaft just fits tightly in the hole, during assembly you would put a small amount of gasket sealer in the hole just before the shaft is slid in. You do not want to use a silicon sealer there.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Thanks Truckrolet, That is the one thing I did not take apart when I put in the new gaskets. | | |
