| | | Forums66 Topics128,084 Posts1,056,083 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71856 01/17/2007 10:26 PM | Joined: Nov 2006 Posts: 25 Junior Member | | Junior Member Joined: Nov 2006 Posts: 25 | Additional info follows. I just bought a used 250 and want to start it before I intall it. I just hooked the positive on a battery to to the starter and the negative to the block and used a remote starter switch. The starter keeps cranking after I release the button. Is it wired incorrectly or maybe it needs to be shimmed? Does it take any power to disengage the starter or should it just release though spring pressure? Any suggestions will be appreciated.
More info.
I forgot to mention that I took the starter out and "bench" tested it, it seemed to work fine. The gear came out spun and released. So I am guessing I had it wired correctly. Also a powerglide is connected to the engine but I don't believe this would contribute to the problem.
Would it seem that the starter needs to be shimmed? | | |
