| | | Forums66 Topics128,154 Posts1,056,831 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | Gonna tackle for the first time. Lookin for guidance of anyone who has used the glue to do the pans. I really dont want to tack weld. Also where to buy the pans to do the least trimming and best cost. Also what cheaper product than POR 15 to coat them.
| | | | | Joined: Jan 2011 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 85 | ehh while the glue is supposed to be good i don;t knwo if i woudl trust it on a floor. That is just my opinion. Panels that the driver seat and all the pasegners are on is different than a panel that doesn't have any real "weight" to it.
52 Chevy 1/2 ton - work in progress 65 Mustang coupe - work not in progress  67 Mustang GT convertibile 67 Camaro RS/SS We are now even with fords and chevys. Now i need a mopar. Hahahahahahahahaha
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If you just want to keep your feet from draggin' on the pavement, why not? Heck, for that matter just screw a piece of galvanized sheetmetal over the hole.
Seriously, you have to ask yourself what you're trying to accomplish. Are you going to keep the car and fix it up or just drive what you have? Figure that out and proceed accordingly. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I used the glue on a trunk panel in our Nova, but like you I didn't trust it , so I went around and put some tack welds on it. But my friend the body man said I really didn't need to! I used POR15 great stuff though costly! | | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | I plan on doing just the floor pans themselves, not the area where the seats mount. What type of glue brand did you use? I have read where body guys swear by using the glue but cant find the brand. What else is cheaper than POR 15 and does the same job well? | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | 3M 2 part panel glue. I used POR 15 even though it was more expensive, in fact on the 53 it coats the inside of my fenders, inner fenders, nd rear fenders. I trust the stuff! There is a dispenser that was needed to apply the glue, I borrowed one from my local body man that is a friend of mine! | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Several years ago I bought a 56 Ford that the previous owner had repaired with soft aluminum formed to fit the floor and then pop riveted it in. Actually, it wasn't too bad of a fix. However, I didn't like knowing it was there and seeing the pop rivets from the bottom side of the car. I cut out the old rusted out area with a plasma cutter and plug welded repair panels in and then put a small bead along the edges. With a carpet, it appears to be like new. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I'm not sure how it goes with your State inspection laws,but over here 'glued' panels simply wouldn't pass the test. I accept floors are less 'structural' when you have a separate chassis,but for me and for peace of mind I would weld them in.JMHO.
Here,bonding agents such as the 3M products are allowed for extraneous panels such as fenders on a monocoque design, but any repair to the main bodyshell must be welded. The annual test here though does not make any exceptions for separate chassis/body configurations.
I do agree that bonding panels can actually be stronger than a weld nowadays. In fact I fit bonded windshields for a living,so I know how strong some of these products are. We just have to work with what the law here dictates.
If you do decide to go down the glue route,preparation and cleanliness is everything... Your bond is only as good as the material you're joining together.
P.S I'm also a fan of POR-15,sure it's a bit more expensive but it works....
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Some of the present day pickups have a bonded roof panel. I believe Dodge does that. | | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | Thanks so much guys. Has anyone had any experiences with the floor pans from EMS? Any other places to buy them or not? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I bought body panels for my 38 Master from EMS and they are really nice. The floor panels for the same car from EMS are flat hotrod style panels. That made me go to Classic 2 Current for my 38 Chev floorpans. I just noticed today that C 2 C carry several versions of the AD floorpans. I think they are different the the ones sold by others. Here is their website: Classic 2 Current | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The quarters have been glued on pickups for a few yrs now, as well as car fenders & quarters. my buddy actually prefers it-no rust issues ever, no distortion.
On newer stuff he's worked on, I've often seen the metal tear before the glue let loose. My next project will get glued on the non-structual stuff. If you can borrow or bargain a dispensing gun it will help, as they are pricey. | | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | I will check into it. Thanks again | | | | | Joined: Jun 2007 Posts: 30 New Guy | | New Guy Joined: Jun 2007 Posts: 30 | Dont have an answer for you on the bonded floor. I have found that hte benefit of bonding a panel is to avoid warping sheetmetal. I have chosen to bond quarters instead of MIGing which really didnt save me a lot of time, but had no warping. EMS makes excellent panels--the best I have seen next to NOS. I used them when restoring a 49 sport coupe and was very impressed. You will not find any product that will work as good as POR15. They have invested years, and millions coming up with the formula. It's expensive but well worth it. The other bonus is that it is thin and covers very well. A quart will be enough to do a floor. 1950 3100 3 windo 1951 gmc 102 1958 chevy 3200 1959 gmc 102 1963 c20 1959 buick lesabre 1961 buick lesabre
