1 members (klhansen),
161
Mod | | | Forums66 Topics128,089 Posts1,056,140 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 100 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 100 | I just got the tank out of mine and it is in pretty bad shape. A buddy said he had a 57 pick-up tank for cheap if it would work. So would it work or am I better off trying to find a 49 tank? Where would be the best place to look?
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor. 1953 2 ton parts truck Long Gone 1957 GMC LCF On 75 Cadillac Eldorado Frame Updated Feb 2021 | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | If you're still looking at this thread ...
'57 tank is different. Best bet is to buy a new tank from one of our vendors. Any old tank is likely to have issues. I have new tanks in both my '49's and no issues with either of them. Even if you do find a decent original tank, by the time you get done screwing around with tank sealers, dipping or constantly buying new filters, or finding out after a few weeks it still leaks ... you might as well just spend the money up front for a new tank and avoid the hassles.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have had very good luck with Spectra Premium tanks. They are made in Canada and fit perfect. There is a guy in Maryland on eBay who sells them for $185 with shipping. I have bought about a dozen tanks from him. Although the 49 and 57 look similar at first, the early ones fill on the passenger side and the later ones fill on the drivers side. | | | | | Joined: Jun 2007 Posts: 100 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 100 | Thanks for the replys and I had looked at it a couple of times with no responses and was a little bummed. I just got motitvated to get this dump truck running, I got stuck in my back yard and need to haul gravel. I called the local Radiator shop and they said two to four weeks to get the old one cleaned out and probably $100 or more depends. I am now in the market for a new tank.
