2 members (Samantha, klhansen),
308
7
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 18 New Guy | | New Guy Joined: Apr 2010 Posts: 18 | i have a problem that hopefully someone on here can help with. i am putting a th 350 in my 66 chevy c10. but i dont have a crossmember to mount it. i know they make a crossmember that will fit. the problem is i dont have the $100 to buy a new one. i plan on building one. my problem is i dont know know anything about transmissions, i was told the tranny needs to be at the right angle so things dont bind up. my question is how do i find that angle. | | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | yes, you do need to maintain the correct angles. The trans doesn't care what angle it is at as long as the fluid level stays high enough for the pickup tube to suck it up. The most important angle to have correct is the driveshaft angle. If I recall, you want to keep the angle on each end of the driveshaft as close to the same as you can. check out this picture: http://www.jalopyjournal.com/forum/attachment.php?attachmentid=1194679&d=1293946775A TH350 is very easy to mount, as for the trans itself, the only thing that you will have to worry about is the shifter linkage, if you use a cable, it makes it alot easier. An angle finder can help you alot, you can get them at any of the import stores pretty cheap, i think i paid $7 for mine. they look like this: http://www.harborfreight.com/dial-gauge-angle-finder-34214.html hope that helps, jason
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | |
