7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | Has anyone used the petronox (think it's spelled right) ignition on a 250ci engine? If so what are the pros and cons if any. Thanks, Mark | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | I had one on my 230. Now have an hei. The pertonix was just a points replacement in my old worn out dizzy. Hei is far superior IMHO. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy blue67fleetside, I have installed many Pertronix conversions, but none on a 250. As there is a factory H.E.I. available for that engine, that is what I would install, you could probably pick one up at a local wrecking yard for a few dollars, hope that helps. | | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | So the Pertronix just replaces your points. I missunderstood there ad I thought it was an electronic ignition conversion. Guess for now I'll stick with whats there. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The Pertronix unit replaces the points and condenser and might require a different coil (depending on your existing coil's resistance and if you have/need a ballast resistor - I do not know if a standard 250 engine uses one). The Pertronix is an electronic ignition but it is not a GM H.E.I. unit/clone. | | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | The only reason I thought about switching to it was to get away from the points and condenser. | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | You can buy a complete Hei from skip white on ebay for 65 bucks. Plus new wires and plugs. The difference between hei and pertronix is like difference between night and day. Best bang for the buck. JMHO | | |
