6 members (Bill Hanlon, Cletus1950, Rustnut, Bucker, 52Carl, frogfarmer), 81 guests, and 2 robots.
Topics128,178
Posts1,057,063
Members48,460
#71737 01/16/2007 4:11 AM
I have a '49 3600 that I am going to swap the axles to a 1/2 ton so I can upgrade to disc brakes and newer shocks. If I use the 1/2 ton springs, will this lower my truck? I don't want to lower it, as I want it to look as original aas possible. I just want the newer brakes and shocks. If I have to use the 3/4 ton springs with the 1/2 ton axles, that's OK. I won't be hauling anything heavy. I just don't know if there is a height difference between the two.
If you think you can't, you're right. If you think you can, you're right.
#71739 01/16/2007 4:32 AM
Kirk, I have a 48 3600, I put a 1/2 ton axle, from a 52 3100 under the front (the 3/4 ton and 1/2 ton front springs are the same). The rear springs are different between 3/4 ton and 1/2 ton. My 48 had helper springs on the rear. I removed them but left the other springs in place. I put a 1/2 ton rear end from a 64 C10 (3:73 gears) under my 3600. Now I have six lugs front and back with newer brakes and a better gear ratio. I have not noticed any significant difference in the height of the truck....I like the original height too. I now consider my truck a "heavy-half" ton. Scott
#71740 02/06/2007 7:57 PM
I was initially going to do this swap myself on my '50 3600. I opted to swap in the ifs from a '79 half ton. It was mush easier than expected, basically a bolt in affair. You end up with disc brakes and a smoother ride. You can usually find these units pretty cheap.
Robert C.
I'm a Genius in the making.
1950 3600
#71741 02/06/2007 10:30 PM
Quote
You say axles each time, but the dialog here has all been about the front axle and springs.
The rear might be a little more complicated.
The rear on a 3/4-ton is a bit different than that on a 1/2-ton. The rear has an open driveline, not the torque tube that the 1/2-tons had until '55. Also the 3/4-ton rear is mounted fixed and under the springs, while the 1/2-ton rear is pivot mounted on top of the springs.
The rear of the frame is parallel over the axle on your 3/4-ton, but not on a 1/2-ton. So not only are the springs on the sides of the frame instead of underneath, but the alignment of the springs is a little different.
All of this is why I'd suggest you look to put a later rear under the truck, at least a 1955, and that you be prepared to move the spring pads on the axle as you do so.
All this assuming you are planning to do the rear axle too...
#71742 02/07/2007 12:50 AM
I have opted to replace the rear on my 51 3/4 ton with a 10 bolt from a 79 Camero and use a spring kit from Total Cost Involved. If you can find a disc brake set up from a 2002 Firebird it will bolt right to the Camero axles.
~Jim
