2 members (BC59, Uncles51), 103 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#716574 01/30/2011 4:33 PM
Just about every 55-59 I have seen has a broken upper mount and I'm wondering how you guys have dealt with the problem.
Some PO has made a real mess of mine trying to repair them and I need to figure something out. The ones I have are not salvageable.
I can't believe that no one makes these upper mounts because I think they could sell a lot of them.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
I've seen lots that were fine, just depends on how hard they were used without regular maintenance ... and maybe Calif roads are worse than most wink need to do a wanted post for good used, grind off the rivets and replace them
Thanks squeeze. I had to do that on my other '58 back in the 80's. I'll have to see if I can find some decent originals then.
Mike
Are you talking about the round holder that was stamped on the bracket? Or the whole bracket itself?
Dennis
I've had my shocks break but the mounts are OK.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
I don't think I specified but I'm talking about the FRONT upper shock mount BRACKET. I've seen a lot of them that crack just below where the shock mounts to the bracket.
I managed to locate a pair of good used brackets from someone over at the HAMB. I'm surprised that with all the parts that are reproduced, that no one makes these brackets. They seem to be cracked/broken a lot of the time.
Mike
Sorry Mike. I guess I don't understand. Unless they are different from the 55 2nd - they are heavy metal and I have never seen/known them to break. I have seen where the inner stamped collar has come loose.
I am glad you found what you needed. Thanks for the info
Dennis
