1 members (51sub), 128 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
Geezer
Geezer
If so, how does it run?? What kind of mileage does it get?? Do you think it is enough engine for an around town driver??
I got a 305 & T350 in a trade for some stuff and am thinking about using the engine along with a 700R4 that I have in my 1957 3100.
Thanks, all input is appreciated.
Thirdcoast
1966 C20 LWB, 327 4 Bbl., 4 Speed
run it.....
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
I was wanting to run a 305 in my '49 but could'nt find one cheap , plus I already had a 350 that just needed freshening up so I am running the 350 . The factory put 305 with 700r4's together in fullsize trucks and even vans .
Go for it, it is way enough engine for around town. I had an '88 Caprice wagon with this set-up and it was really nice, even loaded on the highway.
You will not burn the tires though, ever! Even in the rain!
'57 Chevy Suburban; '70 Chevy Impala.
Z
Z Offline
As far as burning the tires,according to the gear ratio in the rearend,you think? Keep on Trucking!
I saw a (built) 305 in a mud truck...that thing would scream.
If a little 6 will push it around, that 305 will. 700R4 is a good choice, also.
Performance and fuel mileage will depend on rear end ratio, carburation, tire size, etc.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Should be a good setup.I am running a 350 with a 700R4 and it performes very nice.Also using the stock 3:90 rear,and the OD makes all the difference,economy wise.
Geezer
Geezer
Sorry, did not cover the rear end.. I am leaving the stock 3.90 rear gear and am going to run 235-75X15 tires that have an overall height of 28.8".
This will give me 2230 RPM @ 70 MPH..
I will probably build a 350 later, but I have this 305 & it was basically free...
TC
