| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Hello guys and Gals...I'm restoring another Tri five and looking for help with wiring. It has the bolt on turn signal switch and I am installing the slip on bucket signal switch which is located under the steering wheel. Anyone have a diagram for me? I've located the left and right turn wires.
Also, I am looking for where to put the two wires for the dome lamp on the headlight switch.
Thanks in advance, Steve in Idaho | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Thanks Squeezee!! Heading out to figure it out. Looks pretty easy. | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Hey Squeeze...already thanked ya for the diagram but just wanted to post that it was indeed exactly what I needed in case someone else needs the same info...thanks again, steve in idaho | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 |  that's why I put info "out there" and add the 1inks in my sig, always glad to help folks help themselves  Bill | | |
