1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
DB2
Offline
I have a 1966 C60 firetruck that I parked about 15 months ago with everything working. Today I cranked it up and the brake pedal goes all the way to the floor without any resistance. Any ideas to help me troubleshoot the issue?
Time to crawl under the truck to see where the brake fluid puddle is...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
brake booster is notorus on these trucks
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
Well, first, try the optimistic path. Find the master cylinder, re-fill it with fresh brake fluid, and try pumping the brakes then. (This is the "someone must have just stolen the fluid out of the master cylinder" theory of brake repair.)
This doesn't solve, or even identify, the problem, BUT, it may get you back on the road, at least temporarily. Brakes will want to be bled, and I'd take it slow, easy, and careful while you test the system. Your parking brake works, right?!
I would guess a wheel brake cylinder has crapped out. Evidence might be found by inspecting the insides of each wheel for signs of fluid leakage. Or, yeah, the hydrovac might have gone wonkey.
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Moderated by  69Cuda
