2 members (Joe H, Naturalthud), 196 guests, and 0 robots.
Topics128,080
Posts1,056,062
Members48,433
#715616 01/27/2011 4:47 AM
Hello guys I'm working on a 58 Apache 1/2 ton that needs a little work.I picked up a 56 3800 that has a great cab, front clip and was wondering if the cab and doors would interchange to my 58.Are the hood and fenders the same for a half ton versus a 1 1/2 ton?Thanks for the info and have a great night
56 cabs will work on a 58. 1 1/2 ton hood and fenders will not work on a 1/2 ton.
1.5T is the 4000 series, the 3800 is a 1 ton, which is all the same size stuff as a 1/2T ...
the complete 56 cab and front will fit the 58, but you'll need to cut a couple inches off the 58 frame
[like this 57 on a 58 frame]
OK thats what I thought,I'm gonna swap the cabs and doors around so I have less patching to do.I am gonna sell the excess 56 stuff to help fund the rest of the project.Was allso told that the radius of fenders were dfferent between the 1/2 and 1 ton. Appreciate all the help have a good day
the fenders are the same 1/2 to 1T for the same year, the curve of the fenders where they meet the hood is different between the single and dual headlight ones .... swapping the cab only won't be a simple bolt on, the hood hinge mounting points on the firewall are positioned slightly different on the 58/9
Thank you for that info,what needs to be done?Can I just elongate the holes or do I need to reposition mounting holes?
the hole positioning is too close to move them, new ones would lap the old, on ones I've messed with the holes in the hinge pad could be hogged out, but it's a frustrating process to fit the hood under the best best of circumstances, measure 3 times before modifying anything wink
