2 members (Guitplayer, JW51), 148 guests, and 3 robots.
Topics128,087
Posts1,056,114
Members48,435
Folks I need help on locating a de coding mechanism or chart for chevy and gmc intake and exhaust manifolds.At the same time I'm needing help on telling which of these blocks are 230 and which is a 250; bl ef 3235444 ,gm 7 473433,and last of 3 is a66 836010-2.AS A last favor can you direct me to a gm manual transmission de-coding source? Thanks alot gang.Sid Stephenson
some 230s and 250s share same code. might see if you can see piston top thru plug hole.
