3 members (FishinToms53, Gdads51, Gray_Ghost), 80 guests, and 0 robots.
Topics128,052
Posts1,055,740
Page 2 of 2 1 2
Well not sure about the gas engine world. But As a certified Cummins tech, if you put the rings in lined up your gonna be pulling it back out. It is still a no go in the diesel world. Also if you run out of options the rings may have been put on in the wrong order. But keep it simple.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
U
U Offline
Checked oil level at 200 miles and it is at ADD. Now, should I add more zinc with the oil?
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
I don't think that any additive is going to help your situation. There is something wrong with the build.
1951 1 Ton Completed
I agree with truckernix. Looks like you need to dig into your engine and see what went wrong.
I think you have some broken rings. Will have to pull the head and oil pan to pull the pistons and find out.
I remember getting called in to evaluate an oil-burning problem on a Ford 302 engine rebuild by a local shop when I was running the state trade school shop in Pulaski, Tennessee. After doing several diagnostic procedures without finding any problems we finally tore the engine down. One piston had been installed with the oil ring missing! I think the guy who did the rebuild had a chronic problem with Budweiser fever while he was on the job!
When you pull the pistons, be sure and check the cylinders for taper wear. If there's more than .005" of taper, it's very unlikely the rings will seat well, or last very long. At 2,000 RPM, the rings in a taper-worn cylinder are changing diameter 66 times a second trying to maintain contact with the cylinder walls.
U
U Offline
Drove truck tonight up to my moms house. About 100 miles of San Fran. Truck did great! Still a bit of smoke on the take off. Have 300 miles on engine now. Getting about 9 miles to the gallon, Also noticed the speedometer is about 10 miles slower than those road side speed readers.
More pix
That's good, though I don't know about the 9 mpg. Seems to me it should do a little better, but may not. How much oil (if any) did it use on the trip?
U
U Offline
Hi Roy,
Thats the kicker. None! I checked it just now and the dip stick is a full.
I hear the truck will burn a bit more gas because everything in there is still tight.
Jon
More pix
When ever I here of poor gas millage I wonder if the wrong carb base gasket was used. If the power valve port is blocked by the gasket on the base, there will be no vacuum to it to close it. This has a big effect on gas millage.
Late ignition timing is also a cause.
My Blog
Page 2 of 2 1 2
