2 members (jmoore, Goach2),
87
Mod | | | Forums66 Topics128,194 Posts1,057,264 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 11 New Guy | | New Guy Joined: Oct 2010 Posts: 11 | k got my 55 bread truck... its got 16" drums on the back and 14" up front. why did they do that? I need new tires and at $216 a piece for 700x18s I just cant swing it.and of course 16" dually rims don't fit.. and I want radials.. so.. what the hell do I do? I am going to see if I can locate a later 1 ton HO72 to see if I can get either smaller brakes or the whole axle. unless there is something else i can do? help!
Huh?
| | | | | Joined: Dec 2010 Posts: 21 New Guy | | New Guy Joined: Dec 2010 Posts: 21 | come on dude, the back brakes are bigger because when its loaded, thats where the weight needs to be to stop it, if its empty the front is heavier and only needs the back to "Line up" the braking direction. If it doesn't the truck will spin out (swap ends)of control. As for tires, look for used, junk yards, craigslist excetra. or swap to newer with discs. I just pulled a ho72 514 out of a 67 one ton, going back with a gm corp 14 for gearing reasons and discs | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I would wait until you have the money for the 700 18s they will last you a long time .If you change the type of wheels ,tires or the rearend it will cost much more in the long run. Good luck | | | | | Joined: Oct 2010 Posts: 11 New Guy | | New Guy Joined: Oct 2010 Posts: 11 | 700x18's are non existant used.. I live on ebay, CL, and my local classifieds.. those tires are dinasaurs.. maybe I can find some here.. got no problem running split rims..
Huh?
| | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | The corresponding tubeless tire to the 18" tube type is a 19.5". They can be run interchangeably, even side-by-side with each other. The same thing holds true with 20" tube type and 22.5" tubeless. Quite a few bakeries ran the 19.5's on their delivery trucks, at least the ones in the Nashville Tennessee area. Jerry
