Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (55shaker, 3B, 1 invisible), 144 guests, and 3 robots.
Topics128,281
Posts1,058,472
Members48,490
1 Offline
hey y'all. I'm planning on swapping my stock 62 three on the tree column for a similar column from a 65. are there any fitment issues here? I understand there might be some signal harness changes to make.... is there anything else?
thanks for any input
As far as I know, they are the same from 60 to 66 definately and some from 60 to 72, auto to manuals bolt up, just have to work the issues.
The wiring plug connectors are compatable as follows:1960-61, 1962, 1963-66. I swapped my 63 standard column for a 69 automatic column and had to rewire it completely. The only positive points to the job were a neutral safety switch and 4-ways built in to the column.
