Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (crenwelge), 100 guests, and 2 robots.
Topics128,281
Posts1,058,466
Members48,490
#71135 01/04/2007 9:53 AM
I have a '55 first series 3100 and need help on replacing bad parts that are no longer made. I need the banjo fitting and positional fitting that are attached to the master cylinder. the banjo fitting is screwed into the master and attaches to a 5/16" brake line that goes across the frame under the transmission, and the positional fitting fits around the banjo fitting and is connected to a 1/4" left front brake line. I can't find these parts anywhere and my positional fitting is cracked & stripped. frown Any help would be appreciated.
Tim in California
Tim55Bolt
Tim in California
1955 Chevy 1st series 3100
#71136 01/04/2007 2:44 PM
