1 members (sron48), 104 guests, and 2 robots.
Topics128,154
Posts1,056,856
Members48,456
I am about to put my 55.1 hydra-matic back together. The torus cover has a small groove on the outside surface of the neck that seals with the front oil seal. The new seal seems to be tight. Has anyone used a worn torus cover and had problems with leaks? Has anyone had experience with reconditioning these torus necks? Also have some rather worn shifter linkages (the posts that fit into the levers) that I fear might sheer off. Anyone tried reconditioning these or should I just remanufacture them. This would take some time.
You might try putting a spacer behind the seal to move the contact point with the torus hub to a slightly different position. Even 1/8" or so would be enough to get onto a fresh sealing surface. Check with FATSCO transmission parts to see if they have shifter linkage- - - -they specialize in obsolete automatic transmission parts.
http://www.fatsco.com/index.htm
I've done business with them for several years, and once you get past the "Noo Yawk" attitude case, they're good people!
I took my trans to a shop that was owned and operated by a guy that worked on them when they were new. He failed my torrus cover for just that reason. It also had a worn area about the same place on the inside of the neck. He had me call Leon at www.areds.com and they sent me a remanufactured cover. http://rides.webshots.com/photo/1401771788047579877NSMxhU
