2 members (baldeagle, MickeyP), 101 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#710751 01/11/2011 1:55 AM
ok, Points are good. I like them. But for some of use we want more spark. So here you are. Points eliminator from PreTronix. I installed mine in less then 1 hour. No more points. No more resistors. And a hot Flame Thrower Coil.
Here is the part numbers, I ordered mine from summit racing and I got my Flame thrower coil there as well. Is real nice never adjust points. Comes with a 30 month warranty as well.
For chevy 235 in 59 Chevy Apache 3100
PerTronix 1168 - PerTronix Ignitor® Solid-State Ignition Systems
PerTronix 40611 - PerTronix Flame-Thrower Ignition Coils
Comes with instructions and it will have you remove you resistor to the stock coil. Easy to do. Any questions just ask. Have fun.
There may be a post on this but I could not find it. So im just putting it out there for the poor guys like me.
Also For v6 guys out here pertronix replacement unit is 1162a for ignitor I and 91162a for ingnitor II. One guy on a diffrent site had it in his V6 for 20 years before it gave out on him.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
I installed pertronix on my truck several years ago it's one of the best things I think to upgrade on the old trucks.You should make a TECH TIP and submit to the site.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Pertronix offers more than one part number for the delco distributor.
They have phone tech support that can tell you what part number to order for your set up.
Good luck
I'd suggest pulling the spark plugs and oiling the cylinder walls.
Does a firecracker bang any louder if you leave the match burning after the fuse is lit?
headscratch
Have you verified you are still getting spark by grounding the plug wire?
Dennis
40 Chevy 1/2 ton
What happened here? Someone posted about his success about pretronics, and bout 3 post and 3 years later, it suddebly becomes about ignition problems.
BobS46
A good example of a classic time-warp thought-distortion phenomenon?
