My hydrovac is BAD, I would like to switch over to a Master cylinder with two reservores.Has any body done this without power assits. I like to change over the 1950 ton 1/4. any help would be great!!! Tmix
Hy tmix, go up to Tech Tips, look for specific parts, then brakes, then there is an article on dual master cylinder conversion without power, hope that helps.
