1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | How do you know the difference from a 47-53 suburban, panel or truck vin. is there certain letters,numbers that designate one from the other. Perro
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no indication in the vin, that just tells you the series, like 3100 or 3800
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What year?
Modern-day, standardized VIN's were not available until 1981.
Prior to 1981, manufacturers used non-standard "VINs" (or vehicle IDS or vehicle serial numbers) that might have indicated model (many years did not provide model information, usually just series/size information).
| | | | | Joined: Nov 2010 Posts: 8 New Guy | | New Guy Joined: Nov 2010 Posts: 8 | Seem like I just read a thread about the series number designation. I know my 1 ton panel is a 3805 and I think the 1 ton truck is 3804 but I don't know if Burb. has it's own #. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, models have their designation added to the series numbers, but that doesn't appear in the vin ... xx02=chassis xx03=chassis/cab xx04=pickup xx05=panel body xx06=suburban w/ barn doors xx16=burb w/clamshell xx24=cameo xx34=fleetside pu
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | If it was a GMC, you'd know.:) The S/N will tell you when it was produced. And the mdel number will as well. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1947 to 1953 Suburbans would be either 3106 (panel doors) or 3116 (end-gate), depending on the year. But, as stated a few times above, that information is not on the door-post ID plate (or elsewhere on the 47-53 Chevrolet truck).
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It's not in a GMC serial number either. | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Still a little confused.how would i know what kind of door where on it factory (barn or Clam shell). How or where would i find 3106-3116 stated by Tclederman Or model Numbers stated by Squeeze.or are they just overall designated Numbers by GM. thanks for all the info, hope i'm not confusing anybody.Just trying to educate myself.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the last 2 digits are the model designation, they're nowhere on the truck - the nearest thing is the fender spears that have the series: 3100, 3200, 3600, 3800, etc ... you can usually tell which doors a burb came with because there are two hinge mounting setups on them all and the unused ones for the 'other' setup have cover plates the particular designation would have been on paperwork, as a dealer order or factory invoice, and the 06/16 door difference could have been done at the dealer as well as the factory .... dealer has a sale for a barn door 3106, only has a clamshell 3116 on hand - switch the doors and move it out  Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Bill,
I think you have moved ahead of Advance-Design years when describing series-size designations on "fender spears" (as used/displayed on TF trucks?).
On Advance-Design trucks, the series-size designations were usually shown on the side of the hood (at 1:13am eastern time, your slip is understandable). It should however be noted that specific series-size designations were not on the hood side-plates from 1947 through mid-1949 (when the hood side-plates just showed Thriftmaster for 3100-3800 and Loadmaster for larger than 3800).
But, everything in your clarifying post is correct and helpful (although I prefer the GM term "panel doors" to "barn doors", maybe because I think of many barn doors as being sliding doors).
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | details, details yes, I talk in terms of the TF era, generally applicable before and after ... until this post I hadn't consciously considered the fact that there really is no way to determine the exact model from the vins even tho' the question regularly comes up concerning Cameos .... always interesting tidbits showing up Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | For at least 1947 to 1955-1st series, Chevrolet called the information on the truck's door pillar tag the "vehicle serial number". It included, at least, information about the year, the assembly plant location, the series-number/size-designation, and the sequence/serial number for that vehicle. As stated above, no model information was to be found on Advance-Design trucks. Some states used this door-post-tag code for title/registration. However, the engine code might have been used for those purposes. And, just to confuse us, the same state, in the same year, might have used either code (I have seen engine-codes and door-tag-codes on original titles for 54/55 trucks from both WA and VA). NY will allow either code to be used. | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Thing are finally looking clear. Thanks for your wealth of knowledge. Perro
| | | | | Joined: Nov 2010 Posts: 8 New Guy | | New Guy Joined: Nov 2010 Posts: 8 | On my '57 panel someone wrote 3805 in grease pencil? on the firewall behind the engine. I assume that was from the factory as the engine compartment was never repainted. | | |
