7 members (Gdads51, 68ironhead, PAUL Berardi, Joe H, 3B, Jon G, JW51),
194
Mod | | | Forums66 Topics128,103 Posts1,056,188 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | Does anyone know where I could find a Hood Latch Spring for my '54 Chev Pick Up? I'm having problems finding one. Mine is totally shot. Any thoughts?
Dan Veenstra | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Which spring? The one for the lever or the latch bolt? I've had good luck at the hardware store spring assortment. Probably have to fabricate something. I'll look around my spare parts, might have something laying around. | | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | It's the latch that opens the hood. When you put your fingers in between the grille and hood you release the hood. That release has a small spring built into it.
Thanks, Dan | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I'd check with your local flaps, they have a good selection of springs. Also check out Lowes or Homedepot. I still think a hardware store could come up something that will work. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | It's a mouse trap type spring where the latch pivot pin runs through the loop in the spring. Get a spring with a long straight section and has about 1/16" wire size. Clamp a bolt the same size as the pivot pin (or one size smaller)in a vise and using two vise grips wrap the spring wire twice around the bolt keeping the loop as tight as possible. The original spring had two legs to the latch but since this will only have one you can file a small notch in the release lever and latch housing for each end of the spring wire to fit into to keep aligned. You will have to experiment a little to get the two legs at the correct angle and proper tension when the pivot pin is through the loop but it's not rocket science.
Evan
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you want to see what the factory spring looked like go to my photo site and it's the first picture. It is VERY hard to duplicate this shape working with spring wire. http://s32.photobucket.com/albums/d41/coilover/
Evan
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | Call dan at little valley auto ranch in Belton tx, he probably has one in stock and can ship it out to you 254-939-8548.
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
