| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | Hey Guys...
Can you help out a fellow Stovebolt member. He forgot his password and is having problems re-setting it.
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | I just saw the note about Yahoo emails. Dave has a Yahoo email account. Not sure if that is causing his issue.
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the 'forgot password' feature is where you plug in your name &/or email name and hit 'forgot password' again and a new password is mailed to you, tell your bud to do that .... after you get on with the temp password you can go to 'edit profile' under 'my stuff' above and reset your own password and you don't need to give anyone his email, it's on the record  Bill | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | CHEVYDAVE7 must be getting older like most of us here. I've forgotten mine a time or two as well. | | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | CHEVYDAVE7 must be getting older like most of us here. I've forgotten mine a time or two as well. Age is an issue of mind over matter. If you don't mind, it doesn't matter. ~Mark Twain I have forgotten so many IDs and password then I care to remember and I am only 45...
