4 members (Phak1, carbking, 2 invisible), 115 guests, and 3 robots.
Topics128,260
Posts1,058,322
Members48,485
I have an 848 head on my 261 (yep, the holes have been drilled). It has the two-piece thermostat housing with each piece having the extra threaded holes. How are those holes used?
Do you connect them with fittings and short length of hose?
Thanks!
Run an extra heater for the drivers feet grin
I believe you should be able to find pipe plug fittings to block them off.
Yep. Brass or cast pipe plugs work fine.
If you do not need the hot water for a foot warmer, use the extra outlets to heat an Offenhauser intake.
Tim
Luke, To heck with the feet. I'll run a coil of hose in the driver's seat!
What are those holes for? If you connect them, you defeat the purpose of the thermostat.
I will drill a 1/8 in. (or slightly less) hole in the thermostat plate to eliminate any steam or air build-up.
Tim, Your post beat my reply. Intake warmup seems like a great idea. I just put in a frost-plug heater. It's only 500 W but it's below the manifold and puts the heat right where it should be. After 5 hours of heat at 20 below, the old 235 would start right up. I'll also use a 250 W magnet heater stuck to the oil pan when it gets really cold. I have a nifty 2x2 set-up to put it on and take it off without having to crawl under the truck.
Wally,
My 261 that came from a school bus had them, and as Mechainiac said, they were hooked up to a second heater (in the back of the bus).
Tim
One of those sets is supposed to go back to the water pump, whether it is by way of a heater core or just a hose. The whole purpose of the bypass thermostat setup is to allow water to circulate through the engine and head without hitting the radiator to keep the whole block a uniform temperature.
Paint & Body Shop moderator
I think I'm getting it!
I should hook the heater core to the lower of the two holes on the thermostat housing, right? That's the hole below a closed thermostat. The hole above the thermostat will only get flow after the stat opens.
Does it matter which of the two holes on the water pump is hooked to the heater core? Looks like a toss-up there.
Thanks, again.
