| | | Forums66 Topics128,078 Posts1,056,053 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 3 New Guy | | New Guy Joined: Mar 2010 Posts: 3 | i need help lowering 1940 suburban in the front i heard of a guy in guthrie oklahoma who does it if i can get help
viejitos de okla
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Maybe consider using a Mustang 2 front end. Works well on my '40 pickup. Used 2" drop spindles as well. | | | | | Joined: Nov 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 54 | Really depends on what you want to do in terms of originality. You can likely find a dropped axle for your vehicle so that you might retain the original suspension. A mustang II ifs is a good option as well with dropped spindles and airbags if you want to really get it in the weeds. | | | | | Joined: May 2007 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 35 | I can fix you up with a dropped axle.
Direct buying/selling should take place in the Swap Meet or in Private Messages or in email. Thank you.
Last edited by tclederman; 12/29/2010 3:06 PM. Reason: moderator provided clarification of etiquette
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | gwater agree with folks above as it depends on your end goal. Not sure of width of rails on a 40 but if you want to go IFS checkout crown vic ifs swaps on google. the 2003-2006 ifs drops out with only 8 bolts and can be purchased for few hundred bucks. Looks to be an easy swap. Good luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
