Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (68ironhead, Bill Hanlon, Waveski, Otto Skorzeny, Jon G, 2 invisible), 129 guests, and 6 robots.
Topics128,283
Posts1,058,513
Members48,490
#707027 12/29/2010 4:49 AM
I
I Offline
Does anyone know if a 69 dually rear end will fit under a 1940 1 1/2 ton?
I was thinking of upgrading to an sm420 behind a 261 and both are available locally.
3B Online: Content
3 Online: Content
Hy InMy40s, I don't think it will "bolt in", but I'm sure you could modify it to fit, good luck.
If your spring perches are the same distance apart you might be good to go. If not, what I would do is measure the inside of the tires to make sure they will clear the springs first, and if so reposition the spring perches on the axle. Will probably need to get your drive shaft modified to fit the new dimensions, and I'd think your brake system may need a boost to push larger brakes on a later rear end.
Just me thinkin out loud tho. grin
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
