2 members (greenie-reddy, carbking), 47 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#705 06/18/2002 1:33 AM
Can someone tell me what this engine is?
Code:FIII2GF
The motor is in my 59 GMC and all I know it's a Chevy motor.
It's a V8
The code I found on the right front of the block by the head.
I found other codes on the block 7 3849852
#706 06/18/2002 7:21 AM
Oly Offline
A few questions. Where did you get this number? Do you have any idea what this engine is out of? How many cylinders does it have? The number you gave I just don't recognize. Maybe someone else can. but I think we need some more info.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#707 06/18/2002 3:41 PM
What you posted was the application code for the engine, meaning what the engine came out of.
If its a chevy V8 motor, the block casting number will be on the rear driver's side of the block. Look behind the driver's cylinder head, at the bellhousing flange. It may be difficult to see it, so clean the area and get a good light. An example number is 3914638. Yours should have a similar string of numbers. Near that number should be the block casting date code. Get it too, to date the block.
What does the engine look like? The older chevy V8s (283-327) had a oil filler tube at the front of the intake manifold, points distributor, ram's horn exhaust manifolds, and 4 bolt valve covers.
Post the numbers here and we'll figure it out.
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#708 06/20/2002 1:50 AM
hello napco59. the mortec list says that it is a 57-66 283. good luck
our garage is a non-profit organization
