3 members (Hotrod Lincoln, delky, Southerntruck), 65 guests, and 3 robots.
Topics128,080
Posts1,055,952
Members48,430
#706920 12/28/2010 9:51 PM
What is the different about the 235 in a car and one in a truck? I saw one that was out of a 56 car and the water pump and fan looked lower. Can it be used in an AD?
mother dear #706923 12/28/2010 10:04 PM
Redryder pix
My Hotrod
mother dear #706924 12/28/2010 10:04 PM
I just rebuilt and installed a 55-235 in my 52-3100 ,yes it can, it has hyd. liffters and has alittle more HP.On the water pump I used a adaptor to use a stock 216 water pump or you can use a short shaft pump I think the adaptor is the way to go ,one if you need a pump when you're on a trip somewhere you can order a 216 pump from any FLAPS and it gets the fan up more in the center of the rad.less trouble with the fan clearing the bottom rad. hose.
It's a very good engine for a AD.
Pete
Pete52 #707172 12/29/2010 8:44 PM
Thank you Joker and Pete.
mother dear #707519 12/31/2010 2:10 AM
ODSS President
ODSS President
I have 56K on a '56 235, daily driver only vehicle. Good engine IMHO.
~ Cosmo
1949 Chevy Half Ton
