| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | I was changing spark plugs on my 350 with headers. I had problems reinstalling the plugs. No room for fingers or sockets, finally I cut off about a 4 inch piece of vacuum hose that fit over the cap on the plug, this makes a little , flexable extension and really helps the alignment and installation. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | you can also just get a inline 6!  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Old trick, but a good one. There's actually a tool out now that's more or less the same idea, but the end of the tube has a textured ball on it that allows for a better grip, especially if your hands are a bit greasy.
Bill Burmeister | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Got one of those, check the gallery | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | How about a flathead, oops that is a ferd. | | |
