3 members (carbking, 2-Ton, Guitplayer), 205 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
#706604 12/27/2010 8:35 AM
i need help lowering 1940 suburban in the front i heard of a guy in guthrie oklahoma who does it if i can get help
viejitos de okla
Maybe consider using a Mustang 2 front end. Works well on my '40 pickup. Used 2" drop spindles as well.
1940 Chevy KC 1/2-Ton
Really depends on what you want to do in terms of originality. You can likely find a dropped axle for your vehicle so that you might retain the original suspension. A mustang II ifs is a good option as well with dropped spindles and airbags if you want to really get it in the weeds.
I can fix you up with a dropped axle.
Direct buying/selling should take place in the Swap Meet or in Private Messages or in email. Thank you.
Last edited by tclederman; 12/29/2010 3:06 PM. Reason: moderator provided clarification of etiquette
gwater agree with folks above as it depends on your end goal. Not sure of width of rails on a 40 but if you want to go IFS checkout crown vic ifs swaps on google. the 2003-2006 ifs drops out with only 8 bolts and can be purchased for few hundred bucks. Looks to be an easy swap. Good luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
