1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Can someone tell me what this engine is? Code:FIII2GF
The motor is in my 59 GMC and all I know it's a Chevy motor. It's a V8 The code I found on the right front of the block by the head.
I found other codes on the block 7 3849852 | | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | A few questions. Where did you get this number? Do you have any idea what this engine is out of? How many cylinders does it have? The number you gave I just don't recognize. Maybe someone else can. but I think we need some more info.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | What you posted was the application code for the engine, meaning what the engine came out of.
If its a chevy V8 motor, the block casting number will be on the rear driver's side of the block. Look behind the driver's cylinder head, at the bellhousing flange. It may be difficult to see it, so clean the area and get a good light. An example number is 3914638. Yours should have a similar string of numbers. Near that number should be the block casting date code. Get it too, to date the block.
What does the engine look like? The older chevy V8s (283-327) had a oil filler tube at the front of the intake manifold, points distributor, ram's horn exhaust manifolds, and 4 bolt valve covers.
Post the numbers here and we'll figure it out.
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello napco59. the mortec list says that it is a 57-66 283. good luck
our garage is a non-profit organization
