| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I got up yesterday morning and began working on my truck again. I figured out that I was not getting enough juice to the coil because the wire to the coil was too small of a gauge. So i fixed it and the truck fired right up. Then I replaced the fuel pump and it runs great. Although I noticed I need a carb rebuild. gas leaks out of the carb.
Now onto the brakes!!! | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Congratulations! It's always a good feeling when you finally solve a nagging problem. Good-luck with the brakes.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Dec 2010 Posts: 44 New Guy | | New Guy Joined: Dec 2010 Posts: 44 | Congrats on your progress. I have been dealing with a lot of the same problems as you. The wire to my coil had been stripped of all the insulation by rats. I replaced the wire and the truck ran great. Good luck on the brakes, I just finished up replacing my shoes and wheel cylinders. | | | | | Joined: Aug 2006 Posts: 18 New Guy | | New Guy Joined: Aug 2006 Posts: 18 | Hi joshua; sometimes a carb leak can be as simple as a piece of dirt stuck in the needle valve of the float & the fuel does not shut off& the carb overflows. Roge. | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Thanks guys, thats what I was thinking with the carb. I going to take it apart in the next couple of weeks. Does anyone have any advice about rebuilding the wheel cylinders and master cylinder before I begin mine? I have the kits so I will start on them soon. Its a 3600 so its the 3/4 ton brakes. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Have a cylinder hone & good set of brake spring pliers. If you have a decent pedal now, it's a good idea to do the master cyl. first, bench bleed, put it back on & pump up the brakes. That way you won't get the lines full of air & it will be easier to bleed. Learn how to adjust the brakes as the Huck brakes have 2 adjustments on each wheel. Make sure the emerg. brake cables are free. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Thanks wrench tender. Sounds like that would be a lot easier. I may have future questions about the adjustment though... I did not know about that thanks for the heads up. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Joshua, one suggestion I can offer on the brakes is to see if you can find new shoes with asbestos linings or asbestos linings that you can have bonded or riveted. Asbestos has a much higher friction coefficient than "organic" friction materials that parts stores have carried for the last 30 years but the asbestos stuff still shows up on ebay.
I put asbestos brakes on my '32 Ford roadster street rod and it was like adding a power booster. Really!
Ray
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You won't find asbestos brake linings anymore, they have been illegal in the US since 1978, unless you happen to find some that have been sitting around forever or they are some chinese knock off junk. Better off using the modern semi-metallic brake linings, that are redily available at the local parts sotre, which will outperform asbestos any day.
Bill Burmeister | | |
