6 members (Oswald, 2-Ton, TexasJim50, stlcardinalsguy, 1955 1 Series, Otto Skorzeny), 66 guests, and 5 robots.
Topics128,180
Posts1,057,157
Members48,464
i've got a 53 chevy 3100,1/2 ton pickup with a dual shaft 12 volt heater motor. the heater housing has got the name Arvin, with the numbers 59 underneath it.
It's a perfect fit but the motor went out. it has been working just fine. i guess old age finally got it. all connections and fuse checks out. still has power to switch. i need to find another dual shaft motor. any ideas, where?
yes, wiring has been updated to 12v. don't know how to post a picture of it here.
blkhrn #705695 12/23/2010 12:55 AM
Did you bench test with a 12 volt charger? You can cross referance at you're FLAPS they should have a book with specs.
Pete
Pete52 #705697 12/23/2010 12:58 AM
Take your old motor into you local parts store. They should have catalogs they can match up a motor easy enough.
Got to a tractor place or a big semi truck repair/parts place. Those use those dual shaft motors in a lot of applications.
blkhrn #705744 12/23/2010 2:53 AM
thanks fellows
blkhrn #705884 12/23/2010 7:19 PM
I have the same kind of motor. They are very hard to find. You may have to have it rebuilt. Mine is in for the second time. If you find a source for a new one, please let me know.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #705891 12/23/2010 7:57 PM
They are not hard to find. Local parts gurus should be able to get one easy enough. If they know what they are doing.
Also, lots of tractors with air conditioning use them. Coach builders for school buses and RV's use them. Semi trucks use them.
Got to find someone that will look in a book with blower motors illustrations and measurements instead of trying to look it up by application on the computer.
Sources: Local parts stores, tractor repair and truck repair centers, RV repair shops all should be able to get a dual shaft heater motor easy enough.
Roy Rodgers #705894 12/23/2010 8:11 PM
Go the following website:
www.4s.com
Choose the heavy duty catalog and scroll down to page 317. You'll find part numbers, dimensions, wiring, you name it.
Get the part number you want and call you local Napa, O'Reilly, if there is a Parts Plus distributor they use the Four Seasons number to order and sell by.
Roy Rodgers #705918 12/23/2010 10:06 PM
Thanks Roy,I think I found one that looks good. I made the rounds and all I got was blank stares before this.
1946 1-ton Panel
MikeE #705920 12/23/2010 10:22 PM
You're welcome.
I spent the last 12 years hunting parts for a living. Some are easy, some take a little effort.
Those numbers should get you somewhere.
