3 members (KEVINSKI, dt235sd, Bill Hanlon), 109 guests, and 2 robots.
Topics128,049
Posts1,055,675
#704700 12/19/2010 2:11 PM
can anybody tell me if a 700r4 will bolt up to a 2002 5.7 vortec that has been rebuilt with a carburated intake. any info would be great as it allways is from you guys.
Are you referring to an LS1? Or to a 5.7 vortec out of a van? I think that the only 5.7 vortecs in 2002 were installed in chevy express vans the pickups and suburbans had gone to the LS series of motors. If it is a 5.7 vortec then yes. If it is an LS based engine the answer is still yes however you will need to buy this adapter from GM 12563532 you would also need a TV cable attachment bracket, and to elongate the holes on the flexplate along with some longer converter bolts.
my50trk #705678 12/22/2010 11:19 PM
Just a little more info for you.
5700
The Vortec 5700 L31 is a V8 truck engine. Displacement is 5.7 L. It is the last production Generation I small-block from Chevrolet. The cylinder heads feature combustion chambers very similar to those of the LT1 V8, but without the reverse-flow cooling. As such, the L31 head is compatible with all older small-blocks, and is a very popular upgrade. It offers the performance of more expensive heads, at a much lower cost. It does, however, require a specific intake manifold (a Vortec head has four bolts attaching the intake manifold as opposed to the traditional six bolts per head). The L31 was replaced by the 5.3 L 5300 LM7. The 2002 model year was the final year for the L31 5.7 L small block V-8 whose origins date back to 1955. The Vortec 5700 produces 255 hp (191 kW) to 350 hp (261 kW) at 4600 rpm and 330 ft-lbf (448 N·m) to 350 ft-lbf (475 N·m) of torque at 2800 rpm. It is currently being produced as a crate engine for marine applications and automotive hobbyists as the "ramjet 350" with minor modifications.
L31 applications:
* 1996–2003 Chevrolet Express/GMC Savana full-size vans
* 1996–1999 Chevrolet/GMC C/K full-size trucks
* 1996–1999 Chevrolet Suburban/GMC Suburban full-size long-wheelbase SUVs
* 1996–1999 Chevrolet Tahoe/GMC Yukon (and 2000 Tahoe Limited) full-size short-wheelbase SUVs
* 1999–2000 Cadillac Escalade
TBI L31 applications
* 1996 G-Series vans over 8,500 lb (3,856 kg) GVW w/ 4L80E transmission
Special applications
* Oscar Mayer Wienermobile
* Isuzu Box Trucks
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
this engine is a 5.7 vortec came out of an 02 box van i think it was the express so am i understanding this correctly that i dont need the adapter for the 700r4. and could i possibly use a turbo 350 or a turbo 400.. i dont know much about this just want to get a trans that will work with this engine that will not have a computer it has been rebuilt fuel injection gone 4 barrel intake installed.Thanks guys!
